SOURCE: Xerox XG-91D 19 in. Flat Panel LCD Monitor
Just tore mine apart so here is some help. You need to remove the two screws on the back of the case on the bottom. Then you remove the front cover it slides toward the top of the screen then lifts off. You can pry it off if that doesn't work. If you want to seperate the screen from the back cover you then need to remove the swivel mount and the other two screws from the back cover.
SOURCE: Colors flashing no picture
wEll
YOU HAVE TO GO TO
WWW.ONLINEWORK.COM
AND THERE YOU'FIND ALL YOUR ANSWERS
SOURCE: logic board for xg-91d serial number E98Z5501032U
I can repair your Main logic board. I do repair work on ebay. my I.D. ecking767. Or search for Xerox under Computer and Networking
SOURCE: compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
