Question about IBM PC 300PL Socket 370 Barebones Kit / Intel Pentium3 667MHz / 128MB SDRAM / 10GB HDD / CD-ROM / N... (RB6563XX1)
Ibm 61h2500 p/n 61h2471 sw1 and sw2 problem
I got this board from a friend and told me that the board only switches on when you have the on/off combination correction at the sw1 and sw2 switches. the sw1 switch has 1 to4 and sw2 has 1 to 8. help. i really dont know anything about the board and what to do.
  • 2 more comments
  • tjmunjeri Jul 22, 2008
    this is the board and the switches are at the bottom left corner. the blue bits...
  • Anonymous Oct 26, 2008
    jumper seting sw 1 1, 2, 3, ,4 on Off ?????
    sw 2 1 ,2 ,3,4,5,6,7,8, 0n Off ?????
  • Anonymous Jan 07, 2009
    The motherboard is convinced in good condition, but i cannot make it on at my screen/ monitor. I had all my slot 1 processor tested on this board, but all came in dissapointing result.
    I try Celeron 300A, Celeron 400 in bracket,P2 400, and all my SDRAM memory collections.
    Pardon my english, foreigner.
    Thank you
  • andrij1956 Jun 03, 2009
    IBM PC 300GL, model 6563-43G, motherboard 61H2500, Intel Pentium3 500MHz works only few minutes after turn on, than hanguped.Ttemperature of pair transistors on the motherboard is high.
All sw1 1-4 and sw2 1-8 = OFF, PIII at 133 MHz, SDRAM at 133MHz, and AGP card 2x, not 4x or 8x.
Try it PII and SDRAM 100MHz after.
Posted on Aug 01, 2008
All off.
How to reset c3803 code bizhub750
If the code comes back, you need a Fusing unit ( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
1. Turn ON the main power switch (SW1).
2. With the Utility/Counter button pressed, turn ON the power switch (SW2).
3. Press [Trouble reset] to release a trouble with [OK] displayed.
4. Turn OFF and ON the power switch (SW2).
Jan 08, 2014 | Konica Minolta bizhub 750
Bizhub 500 error code c-3901
do below once if the code comes back replace the fuser continue reset cause fire ruining a perfectly good day
2. With the Utility/Counter key pressed, turn ON the power switch (SW2).
Jan 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code 3901 konica minolta bizhub 420
sir/mam
Do below once if the code comes back replace the fuser continue reset cause fire ruining a perfectly good day
Jan 03, 2014 | Konica Minolta Office Equipment & Supplies
C-3904 bizhub 500
do this once only. If the code comes back then the fusing unit the hot part is broke, it could be a thermistor, heat fuse, heat lamp or the board that controls it. Have a tech look at the fuser? Do not continue to reset or a fire could occur and that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART)
Dec 31, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
I'm upgardeing my ms-7061's cpu from a 1.5 to 2.2
http://www.msi.com/product/mb/KM4M-V.html#/?div=Detail
Download > Manual >
CPU
Supports AMD Athlon / Athlon XP / Duran (Socket 462) processor.
(Socket 462 = Socket A)
Supports from 1100MHz to 3000+ model.
VIA KM266 Pro motherboard chipset - Front Side Bus support of 266MegaHertz.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
(Same specs as a VIA KT266A but with Integrated Graphics.
The 133MHz FSB support shown is doubled. AMD processors are 'Double-pumped')
VIA KM400 motherboard chipset -
FSB support of 266MHz to 333MHz.
(Same as KT400 but with Integrated Graphics)
VIA KM400A motherboard chipset -
FSB support of either 266MHz, 333MHz, or 400MHz
(Same as KT400A but with Integrated Graphics)
Looking at the Bottom/Right corner at the CMOS battery;
There are THREE sets of jumper pins to the bottom right edge of the CMOS battery.
6 pins towards the outside edge of the motherboard, 3 pins to the inside of the motherboard. (Left side of the 6 pins)
On the 6 pins in a row configuration, the top 3 pins is SW1.
The bottom 3 pins is SW2.
The 3 pins to the inside of them is JBAT 1
In the 3 pins for SW1 the bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Same for SW2. The bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Jumper on pins;
SW1 pins 2 and 3, SW2 pins 1 and 2 = 266MHz FSB support
SW1 pins 1 and 2, SW2 pins 1 and 2 = 333MHz FSB support
For the KM400A (KT400A) motherboard chipset;
SW1 pins 1 and 2, SW2 pins 2 and 3 = 200MHz FSB support
1) What is the model name, and model number of the AMD processor you are going to use?
2) What kind of Thermal Paste are you using?
3) What are you using to clean the bottom of the Heatsink with, and is the top of the Processor clean?
4) Are you following Anti-Static Precautions?
Post back in a Comment.
Regards,
joecoolvette
Oct 13, 2012 | Computers & Internet
Schematic diagram of cobra 148 gtl cb radio china made
  • Locate the MB8719 chip that is right behind the channel selector. Wire a SPST switch from pin 10 to ground and another from pin 11 to pin 12.
  • Channel Chart
  • Position 1: sw1 down, sw2 down
  • NORMAL CHANNELS
  • Position 2: sw1 up, sw2 down
  • 15=26.815 20=26.885 25=26.925 30=26.985(ch3)
  • 16=26.835 21=26.895 26=26.945 31=26.995(ch3A)
  • 17=26.845 22=26.905 27=26.955 32=27.005(ch4)
  • 18=26.855 23=26.935 28=26.965(ch1)
  • 19=26.865 24=26.915 29=26.975(ch2)
  • Position 3: sw1 up, sw2 up
  • 1=27.605 6=27.505 10=27.555 14=27.605
  • 2=27.455 7=27.515 11=27.565 16=27.475
  • 3=27.465 8=27.535 12=27.585 20=27.525
  • 4=27.485 9=27.545 13=27.595 23=27.575
  • 5=27.495
  • Position 4: sw1 down, sw2 up
  • 1=27.605 11=27.725 21=27.855 31=27.955
  • 2=27.615 12=27.745 22=27.865 32=27.965
  • 3=27.625 13=27.755 23=27.895 33=27.975
  • 4=27.645 14=27.765 24=27.875 34=27.985
Nov 09, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
How do i wire in a 2 light colour signal to a 2 way switch
Two Way Light Switch Wiring Have you ever wonder how a lamp that is used to light up the stairs of a building is connected to the two switches that controls it from either end? These two way switches have a single pole double throw (SPDT) configuration. Each has a common terminal (COM) with a pole that can be switched between position L1 or L2. The two way light switch wiring can be implemented by using 2 different methods. Both of the methods used are described below.
The first method as shown in the figure above have the COM, L1 and L2 of both the SPDT switches connected together. For incandescent lamp, the recommended wire gauge used is AWG #18. The LIVE AC Source is connected to L1 of SW1 and one side of the load is connected to L2 of SW2. The other side of the load is then connected to NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is at ON position and the other is at OFF position. If both switches are in the same position, the lamp will be OFF.
The other method is as shown in the figure above. In this configuration, the L1 of both SW1 and SW2 are connected together. Similarly, the L2 of both SW1 and SW2 are connected together. The LIVE of the AC Source is connected to COM of SW1 and one side of the load is connected to COM of SW2. The other side of the load is then connected to the NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is ON and the other is also ON. If both switches are in different position, the lamp will be OFF.
Take note that as the installation involves mains power supply, only those who are qualified and have electrical wiring knowledge should do this wiring. When doing the wiring, it is recommended that the power supply is disconnected from the load and the switches.
Nov 13, 2010 | Computers & Internet
1993 Saturn SW styles
SW1 is a single overhead cam. SW2 is a dual overhead cam both have multi port injection.
Dec 16, 2008 | 1993 Saturn SW1
I'm wondering about 1993 Saturn station wagons. One website describes two models, the sw1 and the sw2. Another distinguishes two fuel injection types for that year's wagons, mfi and tbi. Do they...
mfi = multi port injection
tbi = throttle body injection
the way to tell is look on the intake plenum and see if there is a "carb" sitting there. That's tbi.
Intake plenum with 4 or more fuel lines going to each cylinder is a "MPI" (multiport) system....accordianman
Boolean Logic
I don't know the syntax but you could easily do this with setting the switches to a constant, then adding them up. The number set would need to be something so that there would only be one solution...the one that you were looking for.
sw1 = 1
sw2 = 2
sw3 = 4
If sw1 and sw2 is both on, but sw3 is off, the number would be 3
If sw2 and sw4 was on, the number would be 6
If all were on, the number would be 7, etc.
May 08, 2008 | Computers & Internet
IBM PC 300PL Socket 370 Barebones Kit / Intel Pentium3 667MHz / 128MB SDRAM / 10GB HDD / CD-ROM / N... (RB6563XX1) Logo
1,992 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
