20 Most Recent IBM PC 300PL Socket 370 Barebones Kit / Intel Pentium3 667MHz / 128MB SDRAM / 10GB HDD / CD-ROM / N... (RB6563XX1) Questions & Answers
Either there are no drivers for your audio hardware, or the mixer in deactivated.
Let's try to check the drivers: start>settings>control panel>system >hardware>device manager. If there is any exclamation mark at any device at that window, there is a problem with the driver. The easiest way if there is a problem is to do an on line update.
If the drivers are OK, let's try to find out the audio mixer: start>settings>control panel>Sounds and sound devices. At the Volume panel check that there is a tic at "volume icon at the taskbar".
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
IBM PC 300PL... | Answered on Mar 20, 2010
All sw1 1-4 and sw2 1-8 = OFF, PIII at 133 MHz, SDRAM at 133MHz, and AGP card 2x, not 4x or 8x.
Try it PII and SDRAM 100MHz after.
IBM PC 300PL... | Answered on Jun 03, 2009
Disconnect the mouse and check the pins, sounds like a fault or short. See if it will boot up without mouse
IBM PC 300PL... | Answered on Oct 15, 2008
Have you tried using an external monitor to make sure the video is working on the new motherboard?
IBM Computers &... | Answered on May 08, 2019
I am not an expert in such things but I think if you use a widely available adaptor that will power the old hard drive and provide usb connectivity your Windows 7 should be able to read and allow you to move files, as long as the old drive and the WIN 7 are both 32 BIT (or 64)...
IBM Computers &... | Answered on Apr 27, 2019
hi, try using a vlc player to play, if you dont have download it from here:
http://vlc-media-player.en.softonic.com/download
IBM Computers &... | Answered on Apr 25, 2019
Download NSF to PST File Converter tool to convert NSF data into PST file format. This NSF to PST converter Software nicely convert NSF file to PST, EML and MSG format with whole versions of Lotus Notes NSF and Outlook file.
More Info :- NSF to PST File Converter
Bad memory stick, possibly. Or maybe bad motherboard. try different memory, and try swapping to different slots.
IBM Computers &... | Answered on Mar 18, 2019
Win10 should auto-detect it; so it should need a driver from it manufacture.
Assuming the monitor is properly functioning, and if you are still having problems:
1) Use the most up-to-date connection such as HDMI, DVI, or Display Port
2) Then with the monitor connected, force a Windows update.
3) Make sure the display adapter's resolution matches one of the monitor's supported resolutions.
IBM Computers &... | Answered on Dec 19, 2018
IBM PC 300PL Socket 370 Barebones Kit / Intel Pentium3 667MHz / 128MB SDRAM / 10GB HDD / CD-ROM / N... (RB6563XX1) Logo
Popular Tags
11 questions posted
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Computers & Internet
Most Popular Question
ibm 61h2500 p n 61h2471 sw1 sw2 problem
  • Computers & Internet
