Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn-air 27 inch wall oven - does not heat up properly - display indicates temperature setting has been reached but internal oven temperature (measured by separate thermometer) is well below setting e.g. 400 degree setting results in 200 degrees actual temp. could this be a faulty thermostat?
keith jones
Level 3:
Master:
  • Jenn-Air Master 747 Answers
  • Posted on Feb 05, 2018
keith jones
Jenn-Air Master
Level 3:
Master:
Answers
747
Questions
Helped
314816
Points
1478
Check that the oven thermostat probe inside the oven is not close to or touching one of the upper oven elements
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Jan 09, 2009
SOURCE: Oven heat erratic
no there is not and your unit only has one temp sensor you will have to spring for a new control
Anonymous
  • 1654 Answers
  • Posted on Oct 09, 2011
SOURCE: kenmore digital oven model 79095321303 temperature
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • mc1bean
    Mike Cairns
    • 3054 Answers
    • Posted on Oct 28, 2011
    SOURCE: oven is 50 degrees out of calibration and will not
    Hello, kadid
    I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
    http://home.howstuffworks.com/dishwasher.htm
    Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
    http://home.howstuffworks.com/how-to-repair-an-oven.htm
    Thanks,Mike
    http://beta.fixya.com/users/mc1bean
    mc1bean
    Mike Cairns
    • 3054 Answers
    SOURCE: what should the differential temperature be on a Jenn Air oven
    Hello, mm
    Thanks,Mike
    mc1bean
    Mike Cairns
    • 3054 Answers
    SOURCE: Hello, I have a Jenn-Air W131W, double wall ovens
    Hello, weejay
    Thanks,Mike
    1helpful
    F7 code flashes on jenn aire 27 inch wall oven
    The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
    Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
    I hope this helps.
    7 yr old jenn-air wall oven locked shut, shut down
    It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
    My Jenn Air oven W27200B displays F2 error any solutions? Also one of the burners would hang- one worked and the other didnt.
    HI. this is a failed oven temp sensor or relay board.
    Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode.
    Ohm test the oven temperature sensor, if OK, change power relay board.
    1helpful
    My clock and temperature display is dim
    Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
    If this is a problem, i recommend replacing the control board. it will fix the dim issue.
    3helpful
    My Jenn Air Electric Wall Oven Control panel lights have gone out
    You will need to replace the display assbly.
    It is a very common problem with maytag/Jenn Air
    2helpful
    2answers
    Oven digital lighted display is dim
    mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
    No display, No beeps, No heat
    I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
    Jenn-air expressions 27" convection wall oven model wm27460 won't heat
    reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
    3answers
    Oven doesn't maintain temperature
    When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
    Top Jenn-Air Ovens Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
