Sylvania G-Netbook Logo
Anonymous Posted on Jan 29, 2011
Somehow my husband has deleted all of the applications. I tried to reset by pushing the button on the bottom of the computer. There was nothing in the recycling bin. This happened when he formatted an SD card and tried to install updates. Now ALL the applications are missing. I understand the programs are embedded. I just don't know how to find them now. I would appreciate any help. Also the computer doesn"t recognize SD cards when we put them in.
Kenneth Miller
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 23, 2014
Kenneth Miller
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
315
Points
Give this article a try, a couple of methods here too.
http://redshed.co.uk/blog/recover-lost-data-sd-card/
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Jan 29, 2011
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
528228
Points
7608
  1. Download rec-ova
  2. 2 Extract and run .
  3. 3 Select the deleted files you wish to restore from the SD card
  4. Or can download Undelete plus
  5. follow the bellow link for details
  6. http://www.ehow.com/how_4461259_restore-deleted-files-sd-card.html
    follow all the steps
Hope this helps
JDTec
Level 3:
  • Sylvania Master 4,338 Answers
JDTec
Sylvania Master
Level 3:
Answers
4338
Questions
0
Helped
2128152
Points
14653
SYLVANIA SmartBook Operating System Update:
  • Format an SD card 1GB or larger to FAT32
  • Insert formated SD card into your PC
  • Download and save the sylvania_smartbook_OS_update.zip file
  • Unzip the sylvania_smartbook_OS_update.zip file to the root of an SD card.
  • This should result in the creation of a folder called script in the root directory of the SD card.
  • Insert the SD card into the SmartBook (netbook) device and power on the netbook.
  • The netbook will update its software.
  • When completed, remove the SD card and reboot the netbook.
If you have tried this, please contact customer support:
Call 888-571-0866 or email: [email protected]
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
27helpful
3answers
How can i delete a book from sony e reader. it says to press MARK to delete when i press the bookpage nothing happens and sign like no entry sign appears on bottom right of page
On the PR-500 and the PR-505 readers it IS possible to delete a book without going through your computer. Go into utilities, select delete book, and when told to push the Mark button, which you don't have, push bookmark instead and wait.
2helpful
2answers
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
My mouse does nothing the lights are on but there's no one home
you need to reset the transmitter receiver and the item you changed the battery , the button to reset the mouse and the keyboard is on the bottom and you can use a pencil or pen tip to push the button
first push the transceiver and then push the mouse, good strong batteries are the best.
102helpful
9answers
Sony Walkman NWZ S616F Frozen dead at "Every moment has its music
Find a needle and press the reset button at the bottom by it.I havesolved thesame problem by this way.
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
3answers
Phone keeps rebooting
is the button near the reset hole? possibly the button is somehow pressing the reset switch, possibly stuck somehow. Other than that try a hard reset, instructions below.
Soft Reset
Put your stylus in the hole in the lower left corner where it says “Reset” Soft Reset will reboot your device just like when you reboot your PC. No data will be lost, under normal circumstances that is.
Hard Reset
Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
1helpful
Greeting was somehow erased
Hi Sherrie, I am sorry to hear about your husband, I will do what I can to help. I am fairly confident on that model that if you push the greeting button, then delete it will erase the message for good. Also, if the memory power failed, then it would reset to the default greeting and erase all messages and greetings. However, if the unit has options for multiple greetings (ie. default greeting, greeting 1, greeting 2, etc., then perhaps the default greeting may have been selected, while your husbands greeting is still there but is recorded under say greeting number 1. If that is the case, you can select it to play his greeting instead of the default greeting to have it play. I would find out for you but my computer is having trouble opening the manual on the Panasonic site, so here is the link. Look under "greetings" in the index. Hope I helped. Thanks, CG http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
Palm tx
Fixed - Hotsync all your stuff to your desktop. Remove any cards, and do a cold boot (press reset while holding down power button)
Then synch everything back again. I'm never buying another palm again.
Top Sylvania Computers & Internet Experts
Paul Bade
ADMIN Eric
ADMIN Eric
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
