Netgear is not a browser. It is a Router. For the sake of this question I would assume you were talking about the Router, what do you mean by "Lock"? You can change the default password, and no one will be able to access it. If you only want specific devices to connect to the router, you can:
1) Enable MAC Filtering
2) Disable DHCP, and assign Static IP addresses to the devices
3) Hide SSID (Not Broadcast it)
SOURCE: have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
SOURCE: Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
SOURCE: I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
Configuring WEP:
The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
SOURCE: FORGOTTEN ROUTER PASSWORD
you can accesss it with following default link
http://192.168.1.1 or
http://192.168.0.1
then type username as "admin" and password as "admin" or blank or "password"
then go to wi fi security then go to encryptipn key then checkthat key it is your password for network.
SOURCE: computer will not connect
You have to access the setup wizard of the router, access http://192.168.1.1 username is admin and password is password. Click wireless settings and look for wireless security, you will see there the passphrase and that is your security key.
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below. To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
