The front touchpad panel uses a ribbon cable to connect the buttons and lightd to the electronic control unit. This ribbon cable tends to corrode atvthevpointvwhere it passes through the door to the control unit. You will see a brownish rust on the ribbon cable. A new control panel appears to e around $135.
SOURCE: FDW60P dishwasher. Hotpoint Aquarius Control panel not working
I phoned Hotpoint. Was told to switch everything off and take the plug out for ten minutes - I didnt do that before, I just plugged it straight back in. I did this and was able to run the machine during the night on the programme I wanted. At least if it happens again I know what to do.. This solution will cost you nothing.
SOURCE: amana dishwasher, model adb2200aws, ser
I have the same problem with mine as well but I found out that if you take a space heater to it and warm the control panel up for about 5 minutes, everything works great. This model of dishwasher seems to be problematic in any environment under 70-75 degrees.
SOURCE: My kenmore elite model #
Hi
Thanks for using FixYa. If
the cycle doesn't complete, then the first thing that should be checked is the Timer
and then the heating element. Timers don't often fail. But if every other
part of the dishwasher seems to be working properly and the timer knob seems to
be stuck in one place--doing one function continuously--the timer may be at
fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
