Good chance element is faulty. If you have a multimeter, carefully remove cover on circuit board and check voltage at terminals where element connects for 120Volt AC (hydro). The element is the round rod that slides in side of your stack and 2 black wires go from it back to circuit board. Make sure you have door open and fridge is calling for cool, otherwise you won't get voltage reading there. Best way to make sure it's calling for cool, is to open door, switch to propane, then when it lights on propane, you know it's calling for cool, then switch to AC (hydro) operation to test. If you get voltage reading from spades on board, and element isn't getting hot to touch within 10 minutes, replace element.
