Samsung SIR-S4040R TiVo Upgrade Kits
Check your power supply for normal operation.If not see for replacements at link below
http://www.weaknees.com/tivo-power-supply.php
T's most likely the hard drive. You can replace it and be good to go. It's possible, it's a combo of the motherboard and power supply, but first guess would be try replacing the hard drive.
If you have already reset by unplugging then your problem is some kind of electrical damage. The solution will require internal repair of the devise.
There IS a temp shutoff, but if you're getting no sound at all, it could be that your hard drive has died.
Fortunately, a new drive is cheap (you can upgrade the capacity at the same time) and images and help are both easy to find.
Start your information search at the TiVo Upgrade Center
Click on here to get more info on the problem you have with your device.
If you know how to use a voltmeter, you can check the voltages from the power supply to the other circuitry.
Read last post from stvovance.
What was the problem that you needed to unplug it? How long did you unplug it for? How long have you owned the unit? Where did you purchase it from?
The more information I get the better I can assist you.
Thanks,
Lee
Is it plugged directly into wall power, or into a surge strip?
I'm getting TV solutions rather thaan DVR Samsung S4040R Tivo box solutions. Any help along those lines?
