Sony erickson w610i - on video only, i have a BLACK BAND round the image (as if the image is zoomed in) on the still camara its fine & the full screen is used.
problem only on the video camera - how do i remove the black band around the screen problem only on the video camera - how do i remove the black band around the screen
the problem with that is that it never used to be there, its only appeared very recently, and on a similar phone its not there.
there was a way of putting it on (albeit accidently) so there must be a way of taking it off
any further help/advice gratefully received. 16/7/08the problem with that is that it never used to be there, its only appeared very recently, and on a similar phone its not there.
x its so annoying to know that the black band around the video camara
x (sony e w610i) was put on accidently, & know i dont know how
x to remove it ..
x
x anyone in the big wide world out there know how to remove it ?
x
x
x
x
x
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx
x to remove it ..
x
x
x
x
x
x
You can't post conmments that contain an email address.
If you are zooming in camera (as in, pressing the zoom button while looking at the back of your camera's LCD), you won't be able to save that version.
You will have to open your picture in an image editor and use the crop tool to crop the image to your liking. You can then save that image as a new image. If you don't have an image editor, pixlr.com is a good, free, web-based option.
Image shifts off center and two corners appear
Problem with the Sony Alpha DSLR-A100 Digital Camera That The Sony A200 kit (DSLR-A200K) comes with a DT 18-70mm (3.9x) f/3.5-5.6 zoom lens for an estimated US$600.
A separate Sony A200 kit (DSLR-A200W) includes two lenses: the DT
18-70mm mentioned above, and a 75-300mm f/4.6-5.6 telephoto zoom for an
estimated US$800.
You can download your manual ( in PDF Form) by using the below link. Refer to page 3 and findis a photo and instructions as to where your Sim card goes.
Hi, When a phone falls down on the flow and memory card is affected, Memory cards are very fragile and it needs handling with care. Ones it is affected, it does not work again,that is it is damaged and will not work any more no matter how hard you try to make it work. It just happened to my Sony Erickson phone just some weeks ago,i heard to get a new and i lost all data on the memory stick. So bad.
The best advice is to get a replacement and make sure you back up your data in case anything happens to the memory card.
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
x to remove it ..
x
x
x
x
x
x
