Microwave Ovens Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moffat self clean oven door won't open - Microwave Ovens
Wale Sarumi KomputerSolution
Level 3:
  • Microwave Ovens Master 6,993 Answers
  • Posted on Jan 13, 2011
Level 3:
Answers
6993
Questions
Helped
1701407
Points
1261
Turn of the unit, wait for about 2hrs, then try again. The door might refuse to open if the unit is still hot.
If this does not solve the problem, please let me know.
Good luck.
The oven door won't open. It happened when it wasn't being used. How do I get the door to open?
If it is a self cleaning oven try running it thru the clean cycle to see if the door will unlock at the end of the cycle.
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
Oven door will not open after self cleaning cycle
There is a thermostatic control with prevents the oven door from opening until the oven has COOLED.
2helpful
The oven won't turn off, am leaving the door open so that it won't run
well pull the plug or go out to your circutbraker/fusebox and finde the fuse for the oven.
then you coud try to open the oven (while its not connected to power!) and try to clean the swiches...
9helpful
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Frigidaire wall oven (door opens with hinges on left) won't unlock after cleaning. Turned current off and back on with no results.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
