20 Most Recent Daewoo KOR1NOA Microwave Oven Questions & Answers
One could unplug the power cord and take off the back metal panel.
The turntable runs off a rubber belt.
Be very careful as the capacitor holds one hell of a voltage. It is usually encased by a metal shield... but be very alert.
Do not run the microwave with the cover off..
Daewoo KOR1NOA... | Answered on Apr 25, 2012
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Daewoo KOR1NOA... | Answered on Jul 28, 2011
The key pad assembly is faulty as the carbon contacts get disconnected,the only remedy is the replacement of touch key pad.
Daewoo Microwave... | Answered on Mar 04, 2019
Does it have a turn table that spins your food container? If so, does it turn? If not, you are getting a solid directed beam of microwaves focused on one part of your food leaving the rest of it ignored. If it doesn't have a turn table, it will have a wave spreader inside which is nothing more than an aluminum fan that is sometimes driven by a small motor and rubber belt. You won't see this as it is inside the chamber that contains the magnetron that generates the microwaves. These belts can break allowing a solid, focused microwave beam to shine on your food rather than be distributed around the oven, again, leaving the rest unwarmed. If this is the case, using the oven can damage it over time. If you don't know what you are doing, DO NOT try to repair it yourself!!! If you don't get the outer casing back together properly, you can expose yourself and / or your family to dangerous amounts of microwave radiation. You should take it to a qualified service center for repair but I would venture a guess that it is already damaged because of your statement "but getting increasingly unreliable". Even if it isn't damaged, it will probably cost you more in labor to fix it than it would cost to replace it. Good luck.
Daewoo Microwave... | Answered on Dec 31, 2018
check with DAEWOO website and tech support .
Daewoo Microwave... | Answered on Apr 07, 2018
See my video here:
https://www.youtube.com/watch?v=ITHDE-vFaiw
Daewoo Microwave... | Answered on Jan 28, 2018
Hello Stephanie.
Get a new filter and try again.
Otherwise scrap the micro.
It the filter plate rusted through, or is it burnt?
The microwave's Magnetron-wave-guide is just behind this filter plate.
Looks like a small tube with a silvery cap with hole in center.
Very hazardous condition here.
The high energy from it is damped by the filter.
Is there food in the micro when arcing happens?
An empty micro will arc.
Daewoo Microwave... | Answered on Nov 22, 2017
Daewoo KOR1NOA Microwave Oven Logo
14 questions posted
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Microwave Ovens
Most Popular Question
turn table not turn suppose
  • Microwave Ovens
