If the two cd's which are stuck, if you can see that cd's then pull the cd with pliers.Its a two mouth pliers to pull the things out.The cd may get cracked/ break while removing.But if the cd's are not seen or its very hard stuck, then in that case.The cd player has to be removed out of dash.Yes it will be time consuming, and will not be very simple.But once the player is out, its not much to do.The cd player bottom has few screws to be removed.Once you remove the screws, the complete top assembly will get lifted.You can say" complete casing" will be lifted.Once the casing is out.You will visually see the cd, and you can manually slide the cd out and remove it.----------
Click this link for cd player removing procedure from dash :---------
http://whoisbyme.blogspot.com/2011/08/how-to-remove-cd-player-from-dash-of.html
This will help.Thanks.Helpmech.
grab some hemostats and probe the middle of the slot for the cd's edge. Clamp and pull.
The only option other than reaching in a grabbing the disk would be to remove the entire middle dash panel by systematically removing all bolts, removing the cd player, opening the top of the unit and "plucking" the disk out, only thing is you are likely to continue having this problem unless the unit is replaced or you found something obstructing the disks path the you where able to remove.
I have a 06 Z71 and it did the same thing so more than likely your just going to have to buy a new cd player. I would recommend going with an aftermarket cd player because you probably going to spend just as much on another stock unit.
The same thing happened to me when my 05 colorado was new. If you play homemade cds, that have the old paper labels, they get stuck in the player. sometimes if you take the player aprt and get the cds out it will work again. But I have seen them get ruined from this also and have to be replaced.
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio. Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit. Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
you can try the paper clip in the pin hole all cd players come with manual eject push straight paper clip in cd pin hole this can release the cd
or use old cd gently push in on the other cd to help un jam that cd
