You can doing using a toggle switch inline on the brake wire . If you have the remote then there is a sequence code you can put in which consists of , ok this is very easy
1. have your player on radio (am/fm)
2. go to settings (must have a remote)
3. click the language button (next step is where you need the remote)
4. type in the following numbers 543210 (make sure you hear the beep)
5. a new menu appers after the code (hard-drive)
6. click on the break-bypass button
7. turn on the bypass
8. click the x on the bottom of screen
9. your all set now you have your player unlocked so you dont need the parking break
10. REMEMBER
SAFETY IS FIRST PLEASE BE VERY CAREFUL WHEN USING THIS UNIT PAY
ATTENTION TO THE ROAD AND NOT THE PLAYER YOUR LIFE IS MORE IMPORTANT
THEN THIS DEVICE
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
You need the remote to do the code thing, or try hooking the parkbrake sensor up to full time power to trick the unit into thinking that the parkbrake is off. Try that and see how you go. If it doesnt work that way, try taking it to full time chassis(earth)
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
with the remote:
press set up button
scroll to highlight language
enter 5,4,3,2,1,0
you will now be in a secret menu
turn on brake bypass
and exit
done
