Cars & Trucks Logo
Posted on Jan 09, 2011
The electrical system all of a sudden stopped working on my 1994 chevy silverado 4x4 truck. Yesterday everything worked fine, but today nothing. Any ideas? Does anyone have a wiring diagram?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
237
Points
Did you get it fixed? How??
I have a 94 chevy Silverado 5.7l with 4l60 transmission will a 97 chevy Silverado 4l60 work even if the speed sender is on different side and made different on transmission
Chevrolet / GMC / GEO Transmission Look Up Table
www.autorepairmanuals.biz/page/372807
Blazer, 1993-, 4L60-E. Blazer, 1994 - Up, 6.5L V8 Turbo Diesel, 4L80-E. BLAZER/TRAIL BLAZER/JIMMY, 1995-2003, 4 SP RWD/4X4, L4 2.2L L6 4.2L V6 4.3L ...
Transmission Applications - GM Automatic Transmissions
www.gmautomatictransmissions.com/transmission_applications.php
Avalanche, 2001-06, V8 5.3L 5.7L 6.0L, 4 Spd RWD/4X4, 4L60E. Avalanche, 2004-06... Camaro, 1994-05, V6 3.4L 3.8L, 4 Spd RWD, 4L60E. Camaro .... Monte Carlo, 1997-05, V6 3.8L (W/S.C.), 4 Spd FWD, 4T65E. Monte Carlo ... Silverado, Sierra,1500-3500, 1995-06, V8 4.8L 5.0L 5.3L, 4 Spd RWD/4X4, 4L60E. Silverado ...
4L60E Transmission Rebuilt ' eBay
2answers
Can a 94 chevy cheyenne transmission interchange with a 97 chevy silverado tranmission
Will it physically fit? yes. Will it be a direct replacement any everything hook right up and plug right in? If we are talking about an automatic then no. 1994's wiring was completely different than the 1997. Can it be made to work? possible, but I believe it would be more trouble trying to make it work than if the correct transmission were located and installed. If it is a cost issue where he has a good trans out of a 1994 he might see if a salvage yard will do some partial trading for the correct trans.
My 1994 gmc 1500 truck will not go in to 4 wheel drive the lever and linkage seem to be working fine. the 4 wheel drive worked fine yesterday and nothing today.
Your problem is the electric actuator . You can search on it, and find the solution.... It could be burned out, or sometimes the connector to it gets loose... try cleaning up the connection first, and try it again... It is on the front axel....
I have a 2004 chevy silverado 5.3 4x4. Afew times
Have you had the vehicle checked for DTC'S - diagnostic trouble codes ?.
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Electrical system not working on 1994 chevy K1500 silverado 4x4
Check all your grounding...sounds like you have lost connection at some point.
2004 Chevy silverado 2500HD the left stop light not working
use a testlight turn on the LS light ground the test light touch the pin inside the lamp socket if it lights look for a bad ground if it does not check your fuses or, run a new power wire under your truck secured with zip ties from the switch
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
