LG 42LD450 42 in TV Logo
Posted on Jan 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i find my sky remote code for my tv lg 42ld450
Anonymous
Level 3:
Master:
  • Master 691 Answers
  • Posted on Jan 07, 2011
Anonymous
Master
Level 3:
Master:
Answers
691
Questions
Helped
126674
Points
1740
Google your remote model and search code list and look for your tv brand
1 Related Answer
Anonymous
  • Posted on Dec 28, 2010
SOURCE: sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
1helpful
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
2helpful
2answers
What is the TV setup codes for LG TVs for the SKY remote?
Here are the codes for LG TVs for the sky remote.
Codes provided by SKY:
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367.
Codes provided by LG:
0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851
Regards,
sjstore2
2helpful
I have a LG 42LD450, I read and saw videos online showing that you can enable video playback through the USB port. I also read that u need a certain universal remote to access the service menu does anyone...
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Cant find sky remote code for lg 42ld450
Look at this website :-
http://www.skyuser.co.uk/tools/remotecodes/index.php
Select L for LG then try the codes listed. If none work then your TV probably is not compatible but I have not known this before
Hope this helps
77helpful
3answers
Sky remote code for lg 42LD450 42
5helpful
Can't find code for Sky remote for LG M227WDP LCD 22 TV
I just had to solve this problem. Answer for my M227WDP with a Rev 8 remote was 0206.
My source and instructions are here: http://www.skyuser.co.uk/forum/sky-sky-tv/15406-common-tv-codes-your-sky-remote.html
15helpful
4answers
SKY REMOTE NOT WORKING WITH MY NEW LG 42LH3000
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
4helpful
2answers
Trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
6helpful
3answers
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
1helpful
9answers
Sky+remote code for my lg tv
The cose you need is 0206
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
