Nokia 3110 Cellular Phone Logo
Posted on Jan 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix memory card? - Nokia 3110 Cellular Phone
Gulzar Cherichiyil
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Jan 03, 2011
Gulzar Cherichiyil
Expert
Level 2:
Sergeant:
Answers
252
Questions
11
Helped
52717
Points
805
14helpful
2answers
MEMORY CARD PROBLEM in NOKIA 2730 classic!!!!!! Memory card is not working in my nokia 2730 classic device, even if i insert other mem.card which is working in other phones, the memory card option is not...
Memory card is not working in my nokia 2730 classic device, even if i insert other mem.card which is working in other phones, the memory card option is not seen in my nokia 2730c device.Can any 1 assist me to fix this problem??!!!!.
Thank you.
25helpful
5answers
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
2helpful
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
3answers
How to fixs my memort stick pro duo it keeps
try to insert in other memory reader, if still not work better buy a new one.
4helpful
2answers
MEMORY CARD ERROR, CARD LOCKED BUT IT ISN'T LOCKED HOW CAN I FIX IT
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
3helpful
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Canan 350D with CF error, says no image on screen. How do I fix this?
The memory card could be bad, try formatting the memory card, or the camera could be damaged. Look inside the memory card door, take out the memory card and look at the little pins in the camera that the memory card connects to. If any are bent or missing then the camera will need a major repair to be fixed. This is something for Canon or qualified technician to fix.
2answers
Why my message in N73 memory card cannot be open?
if you have a memory card you can reformat it and that may fix the issue or you need a new card
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
