Most modern mother board will boot from USB devices as long as the USB is included in the boot list of the BIOS and first in line regardless of OS.
Set your BIOS to boot from USB and off you go.
Good solutions above, I have been experimenting with puppy linux also. The bios upgrade might be a good idea, but on mine I went into bios, boot tab, " " to move it to first boot priority, F10 to save/exit. My bios didn't show USB but had "Removable Devices" in addition to CD and HD. Couldn't get USB to boot as a removable device, tried making bootable CF card and connecting to IDE with adapter, it never recognized. Had some problem with CD drive dropping out, found it required hd to be connected I think, if no cd drive, maybe put puppy on hd from other computer.
Http://search.dell.com/results.aspx?s=dhs&c=us&l=en&cs=19&k=usb+boot&cat=sup&x=0&y=0
information on how to do it and also tell you if you need to upgrade the bios
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
