Dell Optiplex 755 Desktop Desktop Computer  Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unsupported memory configuration.please populate dimm1
Catalin Turcu
Level 3:
  • Dell Master 4,924 Answers
  • Posted on Feb 14, 2011
Catalin Turcu
Dell Master
Level 3:
Answers
4924
Questions
0
Helped
1235399
Points
13383
Open it up ..and see what is wrong with the first slot of ram memory ...if the inserted module is not working ...than remove it ..(to check if it works just leave it by itself and try to start the computer ..) anyway ..if there isn't any module in the first slot ..than move one from the last slot ..I mean mount the modules in slots from number 1 to ...as many you have available ...After finish ...restart ..press delete button right the way to go to bios settings ...and in here ..look for optimal factory default settings ..and engage them by selecting with arrows..and enter..and confirm with enter (Y)
to save settings before exit ..press F 10 ..and enter ..
This will assure the ram configuration ...in the correct way ..
Please read careful ..and ask if you do not understand something ...and also ..please rate my answer..cause it helps with my rating and activity on the site..
Aamer Shahzad
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 02, 2014
Aamer Shahzad
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
29103
Points
Use the first slot/port for RAM, if you have two RAMs use 3rd for the second RAM, DIMM stands for Dual Inline Memnory Module, and DIMM1 is the first slot, your error mesage is saying to use the 1st slot for the memory, there are usually 4 slots, 1st and 3rd is DIMM1
1 Related Answer
Anonymous
  • 12 Answers
  • Posted on Dec 29, 2010
SOURCE: when start my pc it
Hi, You can try power drain first. Power off system , disconnect power and press and hold power button to discharge stored power, then remove memory module 1, then reseat it by inserting it with the levers extended to the sides and press down with thumbs until the levers snap in place vertically on their own. if no change, replace module. \quote While reseating the Memory Module please Handle with care. Quote/
My computer is saying unsupported memory configuration please POPULATION DIMM1
The memory in DIMM1 is either missing or the wrong kind. Yes, the motherboard manual or the shop where you bought it should know what to put there. Also, the DIMM1 might not be properly installed or fastened. The arms on each end must click towards the DIMM
Alert ! unsupported memory configuration please p;pulate DIMM1
If the computer was working well and this error popped up, then the most likely issue is a bad memory module, most likely in the DIMM1 slot. If this occurred as a result of a new build or an upgrade, then there are other possibilities. Mainboards are particular in many cases where memory modules can be installed and in what groupings/types/speeds can be mixed and matched. The problem could be as simple as removing and re-seating the memory module in the DIMM1 slot (the slots are usually marked on the mainboard). If there are multiple memory cards installed, try rearranging them, or even removing all but one at a time to try to determine if there are any bad ones. If you are using one at a time, they usually have to be installed in the DIMM1 slot (but not all mainboards require this). After you determine if there is bad memory and which one is bad, you can either replace the bad module, or operate the unit with the remaining good modules, although performance may suffer slightly. The last possibility, and the worst one, is that the the DIMM1 slot on the mainboard is bad. If that is the case, and if you cannot operate without a DIMM in slot 1, you will need a new mainboard or new PC.
3helpful
Alert! unsupported memory configuration. Please populate DIMM1
There should be 4 DIMM slots - two with white tabs and two with black tabs. DIMM 1 should be the white tabbed slot closest to the processor. Slots 1 and 3 (both white tabbed slots) should have RAM installed first, then slots 3 and 4 for additional RAM. If Slot 1 already has RAM in it, pull it out and push it back in to reseat it. If that doesn't work, replace the RAM in Slot 1.
3helpful
System will not boot without RAM in Memory slot 1
http://support.dell.com/support/edocs/systems/op755/en/UG/HTML/memory.htm
If you have memory in that slot, then remove and re-seat it per the instructions in that link
in computers there are many kind of rams a big problems of ram which users are always face is buss speed different. we cant run all type of bus speeds of ram on our computer please replace your ram with the higer bus speed and run it.
and pull out your one ram from your ram bank. i mean to say decrease your ram speed.
1helpful
At starting windows Alert ! unsupported memory configuration please p;pulate DIMM1 (desktop dell optiplex gx 755)
it means the dimm or ram which you plug in your computer is low buss speed so please pull out your ram for pull it out follow these instructions.
first of all open your computers shutter
now you will see the white black or brown long slods on *********** bord
on that slod you will see that the ram or dimm is pluged pull it out open it clips it will out automatically and replace it with the new one of higer buss speed. then start your computer . you will run your computer smoothly thanks
3helpful
Alert ! Unsupported memory configuration. please populate DIMM1 strike the f1 key to continue, f2 to run the setup utility press f5 to run onboard diagnostics
it maybe because u r using more capacity of ram then it support .use less capacity of ram like 512mb, or 1gb. and check it . if it wont work then try it with other dimm slot on your motherboard.
1helpful
When start my pc it gives message Alert Unsupported memory configuration please populate DIMM1
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
