GE Spectra JBP78 Electric Kitchen Range Logo
Posted on Dec 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven not heating at 350 - only gets warm. However broiler element works fine. Do I just need to replace lower element?
Barrett Palumbo
Level 2:
  • Expert 1,772 Answers
  • Posted on Dec 23, 2010
Barrett Palumbo
Expert
Level 2:
Answers
1772
Questions
0
Helped
502260
Points
289
Sorry to read about your problem, I hope this helps you out.
it could be defective element, bad heat probe..or defective control knob..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
eewr
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
2answers
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 • Ovens
2answers
Oven does not work- broiler does
You have a heating element out in the unit. This element is located in the bottom of the unit. Unplug the stove and take out all the racks. There should be one screw on each side of the element on the back of the stove (inside of the unit) take out the screw on eack side and GENTLY pull on the element and you will see wires conected to the element. Dosconet and replace the element. You might see that one wire is burnt and not conected. You might try reconcting the wire and testing the unit. If that is not the case then replace the lower element and problem solved. If you have any more questions feel free to ask and I will be happy to help. Good Luck.
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 • Ovens
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jenn Air W241 bake element not working
Most ovens are relatively simple; an element and a switch/thermostat. Usually it's one or the other that goes bad. If you have a good Volt/Ohm meter you can test the parts saving you un-needed expense.
A Volt/Ohm meter will pay for itself in parts and safety.
A service manual with circuit diagram will go a long way in saving you time and money. Most service manuals are available online for free as a PDF file.
Happy baking. Photo is a pizza baked at 300 o F with Pizzacraft brand pizzeria flour purchased online.
Dec 15, 2017 • Ovens
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
