Power liftgate was opening and I started the van and it jarred the liftgate, now stuck in open position can't close
You will have to remove the panel and remove the motor to unjam it.then plug the motor and turn it on and let it park.then reinstall the motor,this should solve the problem if the motor is not burnt.
Chrysler recalled lift gate call local dealer they should fix for no charge or little charge safety recall!!!!!!!!!!!!
Try reseting it by undoing the battery cable
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
Power Liftgate Module Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1342
ECU Is Defective
INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section.
B2477
Module Configuration Failure
REFER to Section 418-01.
B2522
Vbatt1 Circuit Failure
GO to Pinpoint Test B.
B2552
Vbatt2 Circuit Open
B2698
Vbatt2 Circuit Failure
B2699
Left Pinch Strip Open Or Short To Battery
B2700
Right Pinch Strip Open Or Short To Battery
B2701
Left Pinch Strip Stuck Active
B2702
Right Pinch Strip Stuck Active
B2703
Open/Close Switch Stuck Active
B2704
Optical Sensor Power Short To Ground
B2705
Optical Sensor 1 Input Not Active During Powered Gate Movement
B2706
Optical Sensor 2 Input Not Active During Powered Gate Movement
B2709
Gate Open Output Short To Battery
B2710
Gate Close Output Short To Battery
B2711
Gate Open Output Short To Ground Or Open
B2712
Gate Close Output Short To Ground Or Open
B2713
Unlatch Output Short To Ground Or Open
B2714
Uncinch Output Short To Ground Or Open
B2715
Cinch Output Short To Ground Or Open
B2718
Gate Ajar Output Short To Battery
B2721
Gate Ajar Output Short To Ground Or Open
B2722
Open/Close Switch Active During Self-Test
B2723
Glass Position Switch Active During Self-Test
B2724
Forkbolt Switch Invalid During Self-Test
B2725
Detent Switch Invalid During Self-Test
B2726
Home Switch Invalid During Self-Test
B2819
Gate Motor Circuit Short To Battery
B2820
Gate Motor Circuit Short To Ground Or Open
B2821
Cincher Motor/Unlatch Actuator Short To Ground Or Open
B2822
Cincher Motor/Unlatch Actuator Short To Battery
B2825
Movement Ceased Due To Excess Speed Deviation
B2903
Chime Output Circuit Short To Battery
Power Liftgate Module/ Liftgate Chime Module
GO to Pinpoint Test C.
C1935
Chime Circuit Failure
U1950
UBP Communication BUS Fault
UBP Communi cation
REFER to Section 418-00.
U2338
Invalid ACM Message Data
how to fix dodge caravan rear tailgate wont open
Can't close gate
THE LIFT GATE PISTON HAS COME APART FROM THE TOP OF THE DOOR THE CONNECTOR IS MISSING HOW CAN I FIX THIS
lift gate will not stay open
Gate motor closes before completely open
