Hi
try a partial reset :
Press and hold
and
while plugging in the power cord.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&product=303753&lang=en&cc=us&docname=c00060793
rinus
Hi
Have been through many possible solutions for this and finally got it to clear by holding down the setup button while I switched on the power.
It is all a bit random though: last week, 9 & # worked so I suspect that there is something more fundamental going on underneath.
No error codes whatsoever, only a continuous display of the hourglass waiting symbol :-(
I think that Ken might be right about the root cause being power outages. When I have managed to get it reset and working, the next storm or power outage causes the problem to re-appear. I have worked through #9, #6 etc and each of them worked....once. I have now run out of things to try and like you, will have to replace it. I am loath to do so though as it's otherwise a good bit of kit that has worked well with no problems for three years.
It probably is. When you turn on a printer the machine goes thru a power on reset. Th main board checks different areas of the machine. You should be getting an error code are you?
I have the same clicking problem.
Help !
I have the same problem, but what's the solution??? How can it be hung up on something when we just turned it on??
I tried the cleaning instructions. It made no difference. I'm not sure how having a slightly smudged glass would prevent the printer from powering up anyway. I left the power off all night. I continue with the same symptoms. No power on light. Hour glass on the screen. The hour glass/logo are lit for eight seconds, then go black for two seconds, then back on. At the eighth second there is one muffled click, the screen goes black. Two clicks,then the screen comes back on. The "Clicks" are coming from the little vented box next to where the power cord plugs in.
I have tried every combination of resets. #3,#6,#9 will bring up a partial white screen saying "Full reset" etc. But nothing happens. Reset/cancel? Nothing. Pressing the "on" button does nothing, UNLESS I hold the "on" button down a while then all four function buttons (copy,fax,scan,photo) start flashing and the screen goes blank. Pushing the flashing buttons does nothing. While they are flashing, if I push down the "on" button the flashing function buttons stop flashing but resume flashing when I release the "on" button. It takes a reboot (power off) for the function buttons to stop flashing and for the screen to return to the hour glass.
I'm certain this is due to the power outages we had yesterday during a storm.
When this started the scan tray was in the far right position. When I cleaned the glass I pushed the scan tray to the center, thinking it might realign it self upon power up. It did not move. Also, when I open the front the printer cartidge sled does not move to center but stays locked in the far right position.
I also have reinstalled the software and ran an update.
I've got a lot of work to do. I'm hoping for a quick home cure, otherwise this goes in the trash and I have to drive 50 miles to buy a new one.
Thanks,
Ken
I have the same clicking problem. Its not the first time. it happened before and I just turn it off , after like a month i turn it on it work , But now its back and I dont know what to do ,, plz help
I have the same Problem with my PSC 2410. HP support is very bad...
