20 Most Recent
Smeg CSU2001 Built-in Dishwasher Questions & Answers
How to remove waste hose
Turn off the circuit breaker that controls the dishwasher.
Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
Remove the hose clamp. Disconnect the drain line by pulling the hose.
Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5
Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6
Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7
Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Smeg dishwasher
You can download SMEG dishwasher manuals from here:
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Al.
HELP!!. Have an old smeg
After a while thje dial on Dish Washers, wear out and jam, It sounds like it needs a new Timer, However if it's old, I would replace the Dish Washer.
Dishwasher will not drain
First check for blockage then listen for humming sound when its suppose to be emptying, the drain pump may be blocked or may have died.
