Dryers Logo
Posted on Dec 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hooked up ge dryer 463eg6ww serial number sr746394a The electricity works but no heat? Used a voltage meter and the voltage is correct
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Dec 19, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10845482
Points
101584
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
When I turn on the oven or broiler, the preheat light blinks but why don't the elements heat?
If heating elements are not working, possibly it is caused by electrical issue. You need to check the wires that lead to the heating element hook-up to the heating element. There could be a bad wire or loose connection that is causing the heating element to not work. You may check this using a voltage meter. See attached illustration below for your reference on the details about where to aim the voltage meter. Please proceed with caution when testing this.
If there is no electrical issue on the heating element, possibly the elements are defective and need a replacement.
2answers
Why does my GE gas dryer #DBL333YOWW start hot and gets cold right away?
It might be one of the electric components such as the thermostat.
My Estate Dryer has never been hooked up until now, it comes on but does not get hot or dry the clothes at all, also it has never been used, Please tell me how to fix this problem!
if the dryer comes on but does not dry, you have a voltage problem at the plug or the pig tail is hooked up wrong on the back of the dryer, get a volt meter and check the voltage coming in, you should have 240v....if for shore the dryer hasn't been hooked up or ever used. it could also be a bad heating element. but considering its a new dryer, i'd check the voltage at the plug and check the plug hook up
Feb 10, 2012 • Dryers
Just bought a kenmore 61202 dryer. Hooked it up - everthing works but I have no heat? It is an electric dryer
I would check to see if you have the correct voltage to the dryer at the plug in point. Also check the cord to the dryer with a meter to assure it is the same as the wall connection. It seems something is missing there.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 • Dryers
My GE Dryer.. serial number GL 733 568A. Do not dry clothes, everything else work, except getting hot enough to dry. The dryer just blow cool air..
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 • GE Dryers
We recently purchased a GE dryer and were told it is electric or gas operated, the dryer runs but is not heating up. i think it might be because it isnt getting enough electricitry, but i cant get the back...
If your dryer came with a regular grounded cord attached, it is a gas dryer, and you will have to hook up a gas line to the 3/8 pipe nipple at the lower left corner (when viewed from behind). The 4 prong power cord is only used for electric only models. If still unsure, post the model number from the sticker inside the door of the dryer.
Non-existent model number
That Sounds More Like A Serial Number. Can you Maybe Locate A Part Number On The Switch?
Also Why Did You Determine Its The Switch?
Ohms
volt ohm meter get one at walmart 15.00
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
