The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
Here is a tip that
your dishwasher.
Dishwasher
heatman101
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
heatman101
