Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
Leaves food residue on dishes, mostly glasses and only on top shelf after every wash.
Posted by mvzembryski on
Anonymous
  • Whirlpool Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 27, 2011
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Disherwasher not rinsing well. Top shelf glasses/cups seem to have food residue. Maytag mdbh945awb
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
DishwasherResidue and Film on Dishes
heatman101;;
6helpful
2answers
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
My dish washer is not washing the dishes on the top shelf and leaves a sand like residue on top of the cups and glasses. I have washed out the top spraying arm and washed the dish washer out with vinegar.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
2helpful
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
1helpful
The dishes/glasses on the top shelf are not getting clean
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
2helpful
Dishes and glasses are not coming out clean even inside of dishwasher has some residue left on it after washing
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
Post your model number and I'll try to find a diagram which shows you your parts.
2answers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
11helpful
2answers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 • Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Top Whirlpool Dishwashers Experts
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
