Televison & Video Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought a lg lcd330 32 inches. When i connect my usb nothing happensa i dont get any screen recognizing the usb connection.
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Dec 13, 2010
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801988
Points
33142
Hi msiles. You may have to use your remote control and push the input button then scroll down through that list of input options until you find the USB you are looking for. Joe
I connect the LG GT365 to my laptop to retrieve photos and I get a message that the usb device is not recognized. Do I need a driver for this phone and if so, where could I find one?
it cannot recognize it because you must first install the pc suite cd that comes with your phone.or you may search for it through google.com if you dont have it.install then connect your phone,it must recognize it
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Failed to connect
You need to change usb connection to USB mass storage from your phone. Then it will be ok try it .
4helpful
2answers
Unable to tether my GR500 to PC. PC does not
I currently cant get Att communication manager to recognize the phone is tethered, but i currently have my xp pro sp3 recognize the driver of the lg xenon.
From the main (touch) screen click on the 4 dots (menu)>then the gear (settings)>then select the gear that says "more +"> select connection (should be first option)>select "USB connection"> select "Data Service". NOW you plug in the data cable (dont plug it in before you do this!) and windows should auto pick up the driver for you.
My ONLY problem is getting the ATT communication manager to recognize the phone. it simply says "No wireless device detected". which is garbage because the device manager has no missing drivers and i saw the driver physically installed. anyone else having this problem too???
10helpful
2answers
Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
18helpful
4answers
LG KF750 USB problem
Try going into your connectivity option, then USB connection mode.
Select Mass storage.
19helpful
4answers
LG KU990 USB Connection Problem
in order to send photos,music etc to ur phone u just have to go to phone settings>connectivity>usb connection mode and select mass storage. then use the usb to connect the phone to the computer and that's it.
4answers
Can not connect using LG Mobile Sync
I HAVE LG CU500 AND I WANT TO CONECT WITH MY PC. I HAVE USB CABLE BUT, MENUAL SAYS U NEED TO BUY SD MICRO CHEEP I DONT WANT TO BUY WITHOUT THAT HOW CAN I CONECT WITH MY PC HELP ME
5answers
Syncing won't work
youll need the drivers for them i cant find them online but you may want to try bitpim its a free program that would let you do it without drivers
38helpful
27answers
I have the same problem like everyone else in this forum! here is the solution:
1. The USB modem driver came with the CD may or will not work, so get the latest drivers for it.
2. Before install the new drivers, change your phone setting under " setting -> USB connection -> from MASS STORAGE to DATA LINK.
3. Plug the usb cable to the phone and to your PC, it should do anything or give any message if it does just cancel it for now.
4. Install the new USB driver you just download, while install it will said something like " does not work with XP " just click OK don't panic.
5. After it finished installed you will see by the clock that it find the USB LG blah blah...and ding ding sound if you have sound on.
6. Now go back to LG Sync software and click on Connect & choose LG modem com port whatever it there.
7. You're done !!!
Here the link where to get the new USB driver:
http://it.lgmobile.com/web/web.product.manualSoftwareRF.laf
Yeah the link is all Italian ...don't panic, I couldn't read it either LOL...just click on the picture where you see the phone and the PC with wrap around with arrow, then follow instruction will be in English.
Good Luck!
Keep posting good answer that you find and help out other just like US!
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
