Dishwashers Logo
Posted on Jun 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint Aquarius DWF33 making noises but not filling with water.
  • 5 more comments
  • crumblebee Jun 29, 2008
    Thanks for sugesting replacing the water inley valve. I have found that to order the correct valve I need to know if the machine is a DWF33N a
    DWF33P or a DWF33S. I can not find this on the machine. The serial number is-
    5600041012/03/56/10:11 can you help identify the type of machine it is?
  • crumblebee Jun 30, 2008
    Thanks for that. The number was inside the door , on the top edge. The number is DWF33P. Now I can buy the water valve as you recommended. But the machine looks all sealed up at the back. Where is the valve? How do I get to it?
    Thanks Paul
    Where is the water inlet valve situated in a Hotpoint Aquarius DWF33P? What must I remove to see the valve?
  • crumblebee Jul 01, 2008
    Which panels do I take off to get access to the water inlet valve and the float switch?
    Thanks for your help
  • crumblebee Jul 04, 2008
    Hi
    The machine seems to be all sealed up with no way to see switches, pumps or motors. I took off the plastic kick plates at the front of the machine but there is no access panel at the front. I never did find the float switch. The water inlet valve is at the rear of the machine. The water inlet valve is mounted on the only removable access panel that I found on the machine. It is a small plastic panel. I replaced the water inlet valve and the machine filled OK. Job done. Thanks for everyone's help.
    Paul
    Well played chris.
Anonymous
Level 3:
Master:
  • Master 726 Answers
  • Posted on Jul 04, 2008
Anonymous
Master
Level 3:
Master:
Answers
726
Questions
5
Helped
257106
Points
1674
Water-inlet valve 100 percent sure happened to mine
Anonymous
Level 3:
Master:
  • Master 638 Answers
  • Posted on Jul 01, 2008
Anonymous
Master
Level 3:
Master:
Answers
638
Questions
Helped
223232
Points
1485
You have rated some 1 as best solution .is your problem solved.reply me.
Anonymous
Level 3:
  • Master 983 Answers
Anonymous
Master
Level 3:
Answers
983
Questions
8
Helped
434532
Points
2838
1) First make sure the water is turned on. Check the hot-water supply stop valve, normally located under the sink. Open it all the way by turning it counterclockwise. If there is no reason this would have been turned off since the last time the dishwasher worked, go on to the next step.
2) Turn off the power to the dishwasher.
3) When the dishwasher is cool, look for the float inside the dishwasher; this is usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring-loaded).
Lift out the float mechanism, and clean around the float tube. Many floats must be disconnected from below; to do this you'll have to remove the lower access panel. Rinse off the float, replace it in the tube, and make sure it moves up and down freely.
4) If you're experienced with minor repair work, shut off the hot-water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel; disassemble the valve to reveal the screen; clean debris from the screen; and reassemble. If the screen doesn't appear to be blocked, call a repairperson (he or she will probably need to replace the water intake valve).
5) If none of this helps, call a repairperson. Any of several parts—including the water inlet valve, pressure switch, and the timer or selector switch—may be faulty.
  • Anonymous Jul 01, 2008
    thank you
  • Anonymous Jul 03, 2008
    thank you again
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Jun 30, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
22
Helped
1063597
Points
7105
At the bottom left or right of the dishwasher, there's a water-inlet valve behind the access panel. This valve lets water flow into the dishwasher for the wash cycle. It is usually attached to the hot-water supply line, and to a tube that is then attached to the left or right side of the dishwasher. When the timer sends electricity to the valve, it opens and lets water into the dishwasher. The valve stops when the water level trips the float switch or when the timer stops sending electricity to the valve.
You will have to access this by removing the door from the front, not from the back. Here is an illustration to help you:
http://www.repairclinic.com/0100_26.asp
  • Anonymous Jun 30, 2008
    If you found my solution helpful in any way, kindly take a moment to "Accept" it...Thanks.
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Jun 29, 2008
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
12343
Points
156
The last letter refers to the colour of the appliance.
P = Polar (white)
S = Silver
N = Natural Linen (Beige)
Regards
Andy
Anonymous
Level 2:
Sergeant:
  • Expert 243 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
243
Questions
Helped
95195
Points
598
For the part you are looking for it doesnt matter you can use any of the models as i am showing in my parts guide they are all the same model replacement part. The letter just represents what style control unit it has.
Anonymous
Level 3:
  • Master 6,487 Answers
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1557324
Points
18452
Most washing machines have the rating plate behind the door, either on the inside of the door (don't forget to check near the hinge) or on the door frame of the cabinet. Some hide it behind the kickplate at the base (front) Be careful if removing the front kickplate on cheap machines as they are often thin and the lugs easily break.
If you still can't find it, check behind the pump filter flap or door (if fitted) at the front of the machine. Other than that you would need to check the sides and back of the machine.
Hope that helps........
Anonymous
Level 3:
Genius:
  • Master 3,422 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3422
Questions
Helped
1025596
Points
9479
If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
  • Anonymous Jun 29, 2008
    If there's no water entering your dishwasher, check these:
    Water-inlet valve
    Float switch
    Water-inlet valve
    The
    water-inlet valve lets water enter the machine. If this valve is
    defective, you need to completely replace it. It's usually located
    behind the lower access panel on the left or right side. It's the
    device with the main water line (usually copper) from the house, a
    rubber tube to the dishwasher, and two wires attached to it.
    Float switch
    The
    float switch is a small electrical switch that's located right below
    the dishwasher "floor." Above the switch, on the inside of the
    dishwasher, is a plastic cylinder that floats up as water fills the
    dishwasher. If this switch is defective, or if the plastic float gets
    caught or trapped in the raised position, the water can't enter the
    dishwasher. If the float switch is defective, you need to replace it.
    Ok,I'll let you know if the parts are available for your model.
    Please don't forget to rate or accept the solution.
1 Related Answer
A
Anonymous
  • Posted on Oct 09, 2008
SOURCE: hotpoint aquarius DWF33
it the pump
Hotpoint Aquarius dwf33 is not starting cycle! Making a clicking noise and a whiring noise.
You may have a broken dryer drum belt, pull the back off the dryer and look inside to see if that is the case.
Water is not coming in but if I fill it artificially it will pump out, what is the problem
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
2helpful
Our hotpoint DWF33 Aquarius seems to be going through it's cycle normally but at the end of the program the dishes are not clean, the tab drawer has opened but the tab is still hole. and there is no steam...
i removed the drain cover in the bottom of the dish area ( near the salt fill cap )and cleaned it out. poured boiling water in and closed the machine and ran it with the hottest setting, empty.
this seams to have cured it
1helpful
Hotpoint Aquarius WF325 won't pump out water
Item stuck in pump,open back and take out,unless u r in nottingham i can do 4 u
Aquarius wash and dryer
can u please tell me what the problem is?
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
2answers
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
