Toshiba 46G300U TV Logo
Posted on Dec 08, 2010
Tohsiba 46G300U. What type of video/movie files can be played directly from the USB input using the televisions media player?
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 27, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
2764
Points
18
None you need a dnla certified storage with server function or a connection to your home network to your pc read pages 51 to 56 of the owners manual for details good luck from POPPER951
Why doesn't my Telefunken 32 inch LED media player not supporting file formats for most movies when playing through USB input
Does not have all of the codecs needed to play videos. Common problem. Your Blu ray players are much more universal and give much better playback results.
Sony kvj21mf1ak
It sounds like either the TV or the device is trying to do S video instead of composite video.
see if you can change the output type of the media player and make sure that the TV input is not set to S Video.
Nov 19, 2013 • Cell Phones
How do I get my usb to work on this Boss System
What exactly are you trying to do with the USB? If you are trying to play video through the USB you probably are going to find out that it cannot be done. I would suggest reading the manual again and you will most likely see that playing movies from the Card reader or USB will not be done. Only music and photos will be played, video files will need to be played on disc or sent into this unit from another player via the video input. What you can do is hook up a media player that is commonly used for Home A/V systems to play files from your computer on your TV. They are small enough that you can place them anywhere and hide the wires easily. I've done this before in my car so I know it will work. You can now buy a cheap player for less than $20 if you watch for sales (look for one that runs on 12Volts DC so it's easier to hook up directly in your car). You also may be able to connect a handheld media player to the video inputs but is less convenient than changing out a SD Card or USB Stick that you can transfer from your computer in a few minutes.
How do I put movies on my iCoustic MP3 Player?
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Using usb stick
First you will have either copy and pate the movie or download it to your usb drive
One of the benefits of putting files on a USB flash drive is that you can make any type of file portable.
This includes not only documents, spreadsheets and photos, but also media like video clips and movies.
If you have movies saved on your flash drive that you want to view, watching the movies directly from the USB drive is a simple process and can be achieved on almost any computer.
Connect your USB drive to the device on which you want to watch your movies.
This includes all USB-compatible computers, as well as some select television-compatible devices (like the PlayStation 3, Xbox 360 or Sony Media Extender).
Launch the file explorer application on your device.
In Windows, access this utility by accessing the "Computer" application and then double-clicking the USB drive to display the files.
If you are trying to watch the movie files on a compatible television device, look for a "media," "device" or "USB input" application or button to bring up the file explorer.
Select the movie file you want to play.
In Windows, do this by double-clicking on the file.
The appropriate media-handling program should automatically launch and begin playing the movie automatically.
If you are using a television device, select the file from the list of compatible files in the device's internal explorer system.
hope this helps
2answers
Movie file format
.avi file format is quite common, although some of the newer multimedia type of tv's play more than one type like .mp4, .flv,.mkv and so on...
Save and play video and movies
Check the specification of your MP3 player to determine thetype of video file format it uses.Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. After video conversion then copy the videofiles to your MP3 player using the USB cable from your computer.Click on this link for instructions on converting videofiles for MP3 players :-http://www.fixya.com/support/r5874192-play_videos_mp3_player
How to watch movies on mp3 players
3answers
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
3answers
Windows media has sound no visual when playing
Your media player might be having problems getting the video feed from the USB. try copying the file to your local disk and play the movie from there.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
