Disc not playable :error message using disc that was previously played on Bose Wave Music System Model AWRCC1 serial number 033975C43141210AC:what do I do?
The laser pickup unit [Optical Pickup Unit] is faulty. Bose uses a special type. You can't get it from open electronic spare part market. It is best to get this set repaired by the authorised service center for bose at your town.
The problem is in the laser pickup assembly, buy a CD cleaning kit and follow instructions, If that fails! it must go back to Bose for sevice the only way.
This _might_ be caused by dust or dirt on the read lens of the CD player. The lens projects and reads a beam of light that is bounced off the surface of the CD surface to play the tracks.
Open the lid as if to load a CD. Remove any existing CD. Direct a short blast from a can of compressed air at the lens - or you could use a small artist's paint brush and gently wipe the surface of the lens to dislodge the dust, etc. Do not touch the lens with fingers. etc. as any oils will disrupt the light - and attract dirt and dust.
To resolve this issue, try one or all of the following:
The
Wave® music system is designed to play commercial CDs, CD-Rs,
MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs,
make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
The system may not be able to play certain CD-RW discs. Playability
is dependant on how the disc was recorded, including the format it was
recorded in and the actual disc used for recording. Note: iTunes
defaults to AAC as the encoding format. In order to use iTunes to make
CDs that will play on the Wave® music system, you’ll need to change the
format to MP3 How to Choose Import Options
Different brands of CD-Rs and CD-RWs use different materials which
may affect the ability of a player to read them. If you are burning
your own CD-Rs or CD-RWs, experiment with different brands of discs
If a commercial disc won’t play, check for scratches, fingerprints
or other physical damage. Try the CD in another player. If it still
won’t play, there may be a problem with the disc
Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Unplug the system. Turn the entire unit upside down. The CDs will eject. After I tried this (found it online somewhere), it worked fine for about 2 months. Now it suddenly turns on by itself and ejects CDs (creepy). But at least the original problem was solved.
