Try Pressing the <Num Lk> Key on your keyboard and check again.
You need to use th FN key to turn off the calculator keys. You can also disable this feature from the bios or utility set up. However, if it's just these three keys it may be a faulty keyboard or a driver glitch. Try uninstalling the keyboard drivers from the device manager, the reboot. It will find and reinstall the drivers. You could also check the keyboard connection, they sometimes work loose. If the problem persists after trying these, then you will have to replace the keyboard.
SOURCE: g6000 hen pressing keyboard letter it type 4
Hi there
Does this happen with almost every key, or only certain keys? And if you press a key very quickly, does it still register it as 4 presses?
Also, please confirm the operating system on the laptop, such as XP or Vista.
Please do not rate this solution unless I have answered your question or your reply will not be returned to me. Thanks.
SOURCE: d510 lattitude. Keyboard letters typed,not ones that come up
If the characters at issue are the UIOPLKJM then press Fn + Numlock to turn it off
If other letters are effected Like " and - then go to Regional and Language settings in control panel and ensure you have the correct keyboard/language selected on all 3 tabs
