My laptop's right hand's calculatar key's is not working.
SOURCE: Keyboard Problems
hi you need to stop the "numric keypad overlay" press "fn" and "F11" simultaneously: (page 64) if the URL wont work - just copy the whole link to the adress bar http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=1073792274&ct=UG&soid=112000&BV_SessionID=@@@@0041516997.1144571099@@@@&BV_EngineID=cccjaddhhgjlhjmcgfkceghdgngdgmm.0 good luck
SOURCE: Keyboard problem with IBM R52
Hold the blue fn key (function key) then press the numlk (numbers lock) this will enable or disable the calculator feature on the keyboard.
SOURCE: acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
SOURCE: the letter L key is not working
You have a faulty keyboard. Need to change the whole keyboard since you cannot change just only one letter key.
Note: If machine is under warranty no need to pay for the repairs.
