To view the wireless security key info, you'll need to access the router's set up page. If you left it at the default address - that will be 192.168.0.1. You would enter that number and decimal points into the address box of your browser. I'm assuming that you have access via wireless signal - and simply need to know what the info is for use on another device. If you are not able to connect wirelessly, you'll need to use a computer that is connected by a network cable to the same network.
After accessing the setup page at 192.168.0.1 (or the page you changed it to from the default), you'll be prompted to log in by supplying user name and password credentials. Again, if you haven't changed from the default settings, enter "admin" (no quotes) for the user name and "password" (no quotes) for the password boxes.
If you are not able to get to the set up page because you changed it or you're unable to recall the login credentials, you will have to perform a master reset on the router. More on this, later.
Once logged in, click the Wireless link in the main menu of the browser interface. The Wireless Settings menu will appear. At the bottom of the page, the wireless security options and keys are presented.
A master reset is a last resort to access the settings of the router. If you do not know the IP address or user name and password info, this will be the only way back into the set up options of the router. A master reset will erase all custom settings and replace them with default values - like when it left the factory. This is done by pressing the recessed reset button on the back of the router - between the WAN and LAN ports. Press and hold the Reset button until the Test LED turns on (approx 10 seconds). The router will then reboot with the default operating settings.
You can download the manual for free, here.
Please take a moment to rate this reply - thanks!
