20 Most Recent
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Questions & Answers
My Lexmark Prospect Pro205 printer
A firmware update for the Lexmark Prospect Pro205 printer address print quality issues. Please visit the Lexmark website to download and install the
Lexmark Pro200
Series Firmware Update.
If more than one download is listed for your model, choose the first
download in the list. If it is the wrong firmware level, an error message will
tell you which firmware level is correct. After successfully updating your printer, try to print a document again to verify that the problem is fixed.Should the problem continue even after the update, please contact Lexmark Technical Support Center for further assistance. Thanks.
Lexmark prospect pro205
how do I
If you open the panel where you replace the ink cartridges there is a square hole directly behind the control panel. The area gives you enough space to put your hand under the plastic and you will feel what I only describe as a plastic latch, pull it and you should feel the control panel loosen to then be able to close.
Hope this helps...
How to install Lexmark prospect pro 205
open the laptop and under the control panel tab you will see printers and devices
click on that and at the top click on add a printer
click on the local printer
connect the printer and switch on
follow the installer wizard directions
Will not continue to print
I have to do this every time I try to print more than one job. Why is this happening? It is very time consuming to restart the pc every time you have to print more than 1 job.
Prospect pro205 not printing red
Step one, do a deep clean printhead, which if you have a touch panel on the printer, go to the ink the ink menu - on the top right of the printer panel, press More Options - then choose the option Deep clean printhead.
If you have a
non-touch panel printer, press the
Setup button, and go to the
Maintenance menu, then choose the option
If this doesn't fix it then you may need to update the printer firmware. Here is a link:
Select your Printer Firmware
If that doesn't fix the problem then let me know.
WHY AFTER CARTRIDGE HAS BEEN REFILLED AND REPLACED THE PRINTER SAYS CARTRIDGE MISSING
The trouble with most of the printer ink cartridge manufactures is that they have for a number of years made it harder to refill cartridges and want you to buy them new. It will depend on what model of printer as there are certain cartridges that can be refilled only for that model. Also what can affect your being able to refill cartridges is if your printer has had an update to it's own software, not the driver software.
Why 'paper jammed' message but no paper in printer?
I would try opening the printer up and blowing it out with a can of air really well , unplug it and then see if it corrects the problem .... if that doesn't work I would call Lexmark's 800 # they are always very helpful!
