It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
SOURCE: LCD Monitor blacks in and out for 1-2 seconds
does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
SOURCE: monitor goes black in 2 seconds
Check the data and power cables. One of them might be loose.
SOURCE: When turn on, get a picture for a fraction of a second then blank
I fixed it based upon a suggestion in the on-line manual. I held the "menu" button on the monitor down for more than five seconds, then turned the monitor off and back on, and it was working.
