No matter which input i use ... on power up, the screen displays an image for 2 seconds and then goes black. if powered off and back on again it will display an image again briefly before going black again.
You can check the cable in your monitor,if is ok,you need check power supply or inveter board.if not you need inveterboard our powersupply.you can go to our website to find it :wisiny.com
This sounds like the inverter which powers the display fluorescent has or is failed/failing. If you take a torch to the blacked out display can you see the image faintly? If so the unit needs repairing.
Any error message about inputs? Maybe that clicking sound happens when iit connects to the selected input, but nothing is connected. Can you scroll thru all the inputs? If so, turn on any devices connected to the JVC and scroll thru each input to find the one you're looking for.
The capacitors for the power source are failing. This causes a short burst of power to get to the lamps, but then they cannot hold a charge to continuously power the lamps. You will have to replace the monitor. I suggest checking your warranty status and replacing the monitor.
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
The problem could be the CCFL lamp, especially if the image has a pink hue.
Check LCD Parts for service, parts and DIY info. use this link :- www.lcdparts.net
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
