20 Most Recent Proview PL926WBi 19" LCD Monitor Questions & Answers
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
Proview PL926WBi... | Answered on May 06, 2018
Does it have the square button to the top right to enlarge the picture to normal view?
Proview PL926WBi... | Answered on Jun 21, 2017
Has it bitten the dust? Probably.
Proview PL926WBi... | Answered on May 18, 2017
Try disconnecting the monitor from your computer and checking the pins in the connector to see if any of them are bent or flat. If they are, try to straighten them if possible and that may resolve your problem. Otherwise try resetting your monitor, if it has it as an option in it's configuration menu to do so.
Proview PL926WBi... | Answered on Nov 22, 2014
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Proview PL926WBi... | Answered on Nov 11, 2014
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Public sales or auctions from corporations or schools are the best places to get computer cables for very very cheap.
If you are looking to purchase new cables places like
http://www.pricewatch.com list competitive prices for the cables you are needing.
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
bad capacitors on the board, replace these and the inverters should get there power.
Remove all the screws and stand first, then use thin flat blade screw driver to crack it open at the bottom edge of the case and then work your way around and becareful on the ribbon cable attached to the front panel.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Hi.
Sounds like the power-inverter board is due for an overhaul.
Eventually it won't turn on at all.
I do redo many of these.
Fran
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Capacitors are bad. I fixed one. There was 470 uf that was blown.
Go to electronics store and buy 6x470UF 25v. Thats how i fixed mine
Remove the four bezel screws on the bottom edge of the monitor. Gently pry up where you removed the screws and slide the bezel off towards the top of the monitor. The six mounting screws for the lcd panel will be visible. Remove them and inplug the lcd cables and set it aside. You now have access to the main circuits.
You can not degauss a LCD monitor.
Degaussing is to reallign the magnetic field on a CRT. An lcd has no such field.
http://club.cdfreaks.com/f7/lcd-19-inches-monitor-always-blurred-95364/
The last time I heard of someone wanting a Degauss for an LCD, it was because there kid took a magnet to there LCD monitor. This will destroy the TFT pixels.
http://en.wikipedia.org/wiki/TFT_LCD
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
i have the same monitor and it flashes on and off! i am willing to sell if you want to buy it
can you still see your graphics
Proview PL926WBi... | Answered on Jul 26, 2014
Proview PL926WBi 19" LCD Monitor Logo
204 questions posted
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Proview Computers & Internet
Most Popular Question
not turning blue light blinking
  • Computers & Internet
