This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting. NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside. Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight t Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
canon powershot A470 problem when i click photo then white image come?
but when i use it night it is normal. but during daylight or with
sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Take a look at the settings on your camera. There should be a way to change the white balance. White balance is used when you shoot a photo in the direct sunlight. Have you ever noticed the whites in a picture suddenly look blue? This is because your white balance is turned off or not in the correct mode. The same goes for your pictures that look too white. Take out your camera guide if you have one and look up White balance. You should be able to find the correct settings for the pictures you are trying to take. Hope this helps.
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
If the photo shoot out show white , the obscure (quality variation),
and even horizontal line ( white lines), and so on over-exposure cases,
even if the use of anti-tremor, set to default values are invalid,
because the camera shutter fault.
Can't repair by yourself. It's need repair camera machine shutter.
