Back to:
Tags:
Hotpoint Aquarius WD63 Front Load All-in-One Washer / Dryer
Hotpoint WT540 (by 2 users)
posted by binda16 on Jun 25, 2008
How do I remove the filter pump - I have removed the screws but I can not remove it ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 01, 2008
Where the filter is located in HVL 241 model?
How to found and clean it ?
Solution #1
posted on Jul 15, 2008
Not Rated (0)
POGA
Rank:Guru Guru
Rating: 86%, 13 votes
FIRST YOU WOULD HAVE TO PLUG THE MAINS PLUG OUT THEN TURN OFF THE WATER AT THE RED AND BLUE VALVES THEN TAKE OUT THE DRAIN HOSE AND PUT IT IN A BASIN MAKE SURE YOU PUT THE HOSE INTO THE BASIN ON TOP OF THE MACHINE THAN SLOWLY BRING THE TWO DOWN TO THE FLOOR MAKE SURE THAT IT IS FULLY EMPTYED OF WATER THAN LOOK AT CENTRE OF THE DRUM AND YOU SHOULD SEE A LARGE BLACK HOSE WITH A CIRLCLIP FACING AT YOU RELEASE THE SCREW UNTIL YOU HAVE THE CRILCLIP OFF THAN HOLD THE HOSE AND PULL OUT THE PLASTIC FILTER JUST CLEAN IT OUT AND PUT IT BACK IN REVERSE ORDER AS I HAVE WRITEN
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hotpoint WT540:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WD63 Front Load...
Hi machine stuck on rinse hold and mini wash with lights...
my machine dose not work on the wash cycle, spin, soak,...
Hi, I had an issue with the door which I fixed by draining...
hotpoint washing machine wf645a 1400 spin keeps flashing...
i have a washing machine from hotpoint WD440 when i turn...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
