GPS Logo
Posted on Jun 24, 2008
Can't switch ON
I can't switch on. Press "reset" and hold "power" more than 6 sec. Flash once blue light of Bluetooth and nothing.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
486
Points
11
I pressed only the reset button, (no holding power button) and my tomtom came back to life by itself.
My one set of Scala Rider teamset pro will not let the second set talk to it but the microphone works- any solution?
Do the 2 units pair up when you switch on ? If they do try swapping the units to see if the problem changes from one helmet to the other.
If it does then the problem is with one of the units, if it stays with one helmet then it may be a wiring problem to the speakers.If they dont pairup when you switch on try re-setting the pairing and start again. With the unit turned on, press and hold the CTRL button for 6 seconds till the light flashes red then blue rapidly then press the volume up button for 3 secs, the red/blue should flash 5 times to confirm reset done. Then re pair the units for intercom, switch both units on, when they are flashing slow blue on one unit press the CTRL and Intercom Buttons simultaneously for 6 secs so the red light flashes rapidly, repeat for the 2nd unit, they should both go to a solid red light within a few seconds then slow flash blue to show they have paired for intercom use. If this does not cure the problem you will probably have to send the units for repair.
Hope this helps
Tim
1helpful
I have a Vibe bluetooth keyboard folio for ipad mini--can't find ON switch--nothing on bottom right! How do I turn it ON?
The manual for the Vibe iPad Bluetooth Keyboard Folio is completely wrong. To turn on the keyboard, press and hold the button above the word "charge" in the upper right hand of the keyboard. Blue lights beneath the word "power" and beneath the Bluetooth symbol should flash. In order to pair the keyboard, press the same button above "charge" and hold for a shorter time. The light beneath the Bluetooth symbol should flash.
10helpful
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
8helpful
I have a Noisehush N500 bluetooth and I need help in making it work on my Android I1.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset 2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone, Go to settings, "Wireless & Network", Bluetooth Switch on the bluetooth and scan for devices You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts. 6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
May 31, 2011 • Cell Phones
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
2helpful
My lg vx1100 can not find my plantronics 232 explorer and I do not have the instructions anymore.....can anyone help?
The following are for TB-20EL model. But it works in general for plantronics as well. For step 3 make sure your headset is in pairing mode. When you hold the button 6-8 sec, it should turn either solid blue or blink.
for tb-20el:
1. ensure that your phone's bluetooth feature is on
2.Ensure that the headset is off(press and hold button on your headset (called multifuntcion button) for 2-4 sec, teh indicator light will flash red)
3. press and hold the multifunction button for 6-8 seconds until the indicator light alternately flashes blue and red
4. set your phone to find new device
5. Ente rpin '0000' (four zero) then press OK or yes
6. this should complete the pairing.
4helpful
Need passkey to connect my tb20el bluetooth to my phone
for tb-20el:
2helpful
2answers
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Explorer 220 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
98helpful
9answers
New bluetooth earpiece, no instructions
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done.
Top Clarion GPS Experts
ZJ Limited
ZJ Limited
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Clarion GPS Expert? Answer questions, earn points and help others
