1999 Suzuki Esteem Logo
Posted on May 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Suzuki has since done a recall to inspect and replace the Crossmember /sub frame. I think the letter came out in July. I just got mine done in November ago in Canada. I think the dealership scammed me though and sabotaged it to say they needed to also repair the control arm. But only took me for 60 bux. "a bolt had seized" and it is not covered by the recall warranty. the charge was for half an hour labour to fix the bolt! To the original poster of the question, suggest you contact a Suzuki dealer.
solver2010
Level 3:
  • Suzuki Master 923 Answers
  • Posted on May 15, 2017
solver2010
Suzuki Master
Level 3:
Answers
923
Questions
0
Helped
192879
Points
2907
You got scammed! If a bolt broke off, THEY broke it off, not you! Report the dealer to the bike manufacturer, and ask for compensation, and threaten to take the matter to the National Highway Safety Commission ... and DO THAT if they don't fix the problem!
1 Related Answer
Anonymous
  • 60 Answers
  • Posted on Aug 06, 2009
SOURCE: Same problem with my 2006 XL-7 CD player (constant FOCUS ERROR)
Complete BS. i worked at a suzuki dealership in australia for three years and this is a common problem among others with there head unit in this model eg. not ejecting cds, numerous error codes non repairable, bad reception, the list goes on. i recommend take it further.
Testimonial: "Thanks for your input :)"
2009 Hyundai Elantra Sedan subframe (front K-Frame)
Question edited for clarity, typos and punctuation.
Question moved to model category.
Did you know there is a recall on the subframe and also a class action law suit?
https://www.google.com/search?q=2009+hyundai+elantra+subframe+recall
Limited replacement help but there is a video on the Accent.
https://www.google.com/search?q=2009+hyundai+elantra+front+subframe+replacement
How do I remove the front crossmember for a 2004 Suzuki vitara
RTM yet
FSM
here
https://suzukipitstopplus.com/Products/1145-2004-vitara-service-manual.aspx
read the FSM the factory service manual, it's 4 bucks read it please and ask
any questions not clear, it's all there.
on mine you cant, it's a real frame.. remove it with a plasma cutter?
but you never said what it held up?
the transmission has a cross member. that?
nor did you even say the JOB so we can know what you are ATTEMPTING. ???????
the front frame cross member is a frame, not a part.
it holds the lower suspension A arms . that?
1helpful
2000 Cadillac deville dts sub frame has cracked is it part of the GM recall
Your going to have to remove the entire drive train
& complete suspension, so you can media blast your
sub frame & then TIG Weld it, to make the required
repairs
I wouldn't mind doing the job,but no way I would pay
thousands, to have it done
For recalls you have to ALWAYS ask the parties involved
That is not folks on the internet,it is a Dealer who has the
recall info
How to replace 2000 neon front crossmember or subframe
To understand this procedure go to a wreckers that wrecks your make of vehicle and study the sub-frame and cross member with the engine removed.. I suspect that it will be all welded in
I had the recall done on my sonata 2001 4 cyl auto at the recall for sub frame was done ?
I'm assuming the recall involved control arm failure due to corrosion?
If this was the recall that warranted the replacement of the component(s), it si very possible that when they re-installed the new parts, the frame regained its original stiffness, which will sometimes cause the control arm bushings to squeak. In my years of servicing these components, I've found that the best lubricant is not wd-40, but tire shine products because of their abilities to preserve rubber as well as allowing it to remain flexible. Spray on lubricants have a tendency to eventually dry rot these components because of their chemical mixture.
1helpful
2answers
Recall of 1998 windstar axle replacement in Minn. i never received a letter to have mine repaired. I bought mine in Waseca ,Mn. at Deml's Ford in 1998. I would appreciate a letter so i can have mine...
Hello fellow Windstar owner. I just took my 2001 Windstar into a local Ford Dealer here in Chicagoland to have my rear axle inspected. I can tell you that FORD is taking this recall issue very seriously and with that you will NOT need to produce any recall letter to get your vehicle inspected and then repaired. FORD goes by youre VIN Number as a means to track everything like this recall issue. By the way, FORD really impressed me with the repair that was done tommy rear axle and I am very hard to please (I am a former auto mechanic). You will not have any problems with FORD taking a look at your van.
3answers
Where can i buy a crossmember for a 2002 esteem
The part you are looking for in covered by a Suzuki recall. It was was defective from the start. Take your car to a Suzuki dealership and they should replace the part for you @ no cost to you.
8helpful
5answers
Broken subframeon my esteem. Is there a recall or any compensation. The car was in good shape and now it seems to be worthless. This doesn't seem reasonable.
hello everybody,
I had the same problem on a 2000 suzuki esteem and I checked with the dealer. it looks like there are a lot of problems with the subframe, so suzuki extended the warranty to 12 years or 288 k. I know is a late answer, but might help somebody.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
