This indicates the device driver has not been installed for this device. If you right click on this device and click on upgrade driver, then it may be able to install the driver, provided you have the network/Internet connection. If it fails to find a driver then you will need to go to the laptop manufacturer's WEB site to download that driver.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don
if you are refering to a computer monitor
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps don't forget to vote
