Dell W1700 17 in. HD-Ready LCD Television Logo
Posted on Nov 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on my tv the screem keep black but I lisent the audio.
Grand Canyon Tech
Level 3:
  • Dell Master 3,867 Answers
  • Posted on Nov 27, 2010
Grand Canyon Tech
Dell Master
Level 3:
Answers
3867
Questions
Helped
1177316
Points
12717
The issue here is with the back light on this LCD TV.
What you can do to check this in most cases is hold a flash light to the screen to check to see if there is a image, if so then your back light is the problem and another one would need to be ordered for your tv.
1. Check back light
worse case scenario is the inverter that controls the back light as well that might not be firing.
Thanks for using fixya.com I hope this information is Very helpful to you.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
When i turn on my samsung chrome XE303C12 laptop the screen just flashes nothing else goes black the lights up then goes black again and so on dont know if its something to do with the screem or...
If all the other lights are on as they normally are try connecting a VGA cable from the laptop to an external monitor or LCD TV and see if it displays as it should. If so you have a bad laptop screen. (LCD panel)
2answers
We have a TV Digimate Type DGL2700 model LT27C2M1 We did'nt see the channel Just a blue screem. Can you help us?
Check if the antenna or the cable is properly connected at the back panel. Check also if the TV is set to audio video system or to tv channel .The two must be set properly to receive tv signal.
How to mount samsung t26hd or remove the existing stand?
SAMSUNG T26HD by bsblevy - 10/10/11 11:02 AM HI I HAVE A LCD MODEL SAMSUNG T26HD HE DOESN'T TURN ON, I TRY TO TURN ON WITH THE CONTROL REMOTE ,THE LIGH LED FLASH 4 TIMES AND AFTER I LISTEN A BEEPPPP...BUT THE TV STILL OFF, BLACK SCREEM, IF YOU CAN HELP ME WITH YOUR ANSWER I WILL BE GRATEFULL, THANKS
The tv screem on my ilo 32
The main power supply will be the first place to check. You should have at least the standby 5vdc, which is used for the main board, when the power switch is activated, the main board will send out the signal to turn on the main power supply sections to power up the rest of the set. Look for simple thing like blown fuse or bad capacitors. Learn about what bad capacitors can do.
http://en.wikipedia.org/wiki/Capacitor_plague
Screem Comes on brefly and then fades to black
go to control panel and click on screem after click on screem saver select none or try configurate to more time for to active the screem saver, and if it is not that you must take it to a technician
SCREEM TURN BLUE
The lamps inside of it are weakening, much like a fluorescent light burns out slowly...so get it into a reapir shop OR better yet, Call for an ESTIMATE or replace the whole thing.
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
