Roper RS25AEXLQ Side by Side Refrigerator Logo
Posted on Jun 23, 2008
Ice maker Suddenly one day the ice maker stopped work. I took the line loose and laid it in the sink. water paced through ----not problem. But it appears as though no water is getting to the ice tray. Got any clue what the problem is ????
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 23, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
5592
Points
25
Make sure no one turned off the water supply
1helpful
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
2answers
The pan at the bottom to hold water (Condensation?) is leaking. Never leaked before. We pulled out the fridge (Its on the freezer side) cannot pull it out. Water dumped. It took 2 /3 days to fill up...
The normal run of the fridge will not normally fill the pan, so you have a different source. In this model the water valve is next to the pan. Either you have a leaking water valve or a bad connection to the water valve. Either way the problem you will find is the water valve or line is the cause. Look from the from with a flashlight under the the freezer door, dispense water from the door and watch the valve.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
The ice marker does not make ice. Have looked
If theres water in the line going to the fridge and the ice maker works , most of the times the water valve ( solenoid) that opens when the ice maker needs water , is leaking or doesn't work.
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
1helpful
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
2answers
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
5answers
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Top Roper Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
