The tub seal could be broken or or ripped or torn and the tub bearing and the tub seals both need to be replaced then for your washing machine and dryer machine combo.
if you unplug it and the water keeps running replace the valve where the hoses are connected to but if it overfills and the water stops when you pull the plug replace the pressure switch
The FL error code means: Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things...
(FL is a flood conditon.)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!##@
This problem i see on these are the water pumps getting clogged with
at times. This is not the same washer but all the parts are the same. Please check here for a more detailed appoarch to this problem. Click Here
hi thanks for the question i would check the water level hose. it sometimes gets lint in that small hose remove hose anc clean thanks the appliance doc
