It may be that you are not using the correct code for yourparticular Bose component. I would recommend trying all of these codes: 761,664, 656, and 639. If you are still not able to use your DISH remote to controlthe volume of your Bose component, try doing a power scan. Press and hold theAUX button on the top of your DISH remote until all the mode buttons on the toplight up, then release. Press 2 then * on the number pad, press the powerbutton at the top of the remote, then keep pressing the up button on theremote. Continue doing this until your Bose unit turns off, once it has, stoppressing the up button and press the pound (#) button. Check that the code works by trying several differentfunctions on the remote to make sure it properly operates your Bose component.Keep in mind that some codes may not be compatible with your equipment.
Thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Support Representative
