Radio Communications Logo
Posted on Jun 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
User Manual Need manual for older model Motorola phone/two way radio combo.
  • claudeharmon Oct 18, 2008
    Motorola SX800R 2-Way Radio need a user manual
  • niraj1969 Jan 24, 2009
    There is a disturbance in some areas of our plant?
    What we want to improve the quality of sound?
    Please guide us.
    NIRAJ BHATT
    [email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
643
Points
0
eradiostore
Level 3:
  • Radio Commun... Master 1,672 Answers
  • Posted on Jun 24, 2008
eradiostore
Level 3:
Answers
1672
Questions
0
Helped
797181
Points
4248
Manual for Motorola T5210 Talkabout
The Motorola T5210 manual is available from the FCC ID.io page about that radio. The current link is https://fccid.io/O9GT5210/User-Manual/Users-Manual-146642 . Scroll down to see the manual; the page has a button for downloading the manual as a PDF.
Some documentation for other Motorola Talkabout radios is available from the product support page: https://www.motorolasolutions.com/en_us/support/consumer-radios-user-guides.html .
I hope this helps.
2helpful
2answers
Need a user manual for ht 1000
For this concern that you're looking for the user manual for this device , you can go to this link then download the user manual save a copy of the manual to your computer or print it out for future use.
http://www.repeater-builder.com/motorola/jedi/ht1000-specs.pdf
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
2answers
Need User Manual for Motorola P080 two way Radio
lenbrook.com/motorola/pdf/CFR_T5900_100404.pdf just see this link for the required manual
Sub-Channels
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change. http://www.giantintl.com/motorolafrsold.htm
16helpful
3answers
I can't find a download for the Motorola Talkabout 250 manual
Grasp the black bottom sides of the radio and tug it hard. No screws to loosen. The bottom slides off. The battery placement will be in there.
6helpful
2answers
User manual
Go To http://shop.giantintl.com//Manuals.asp and right in the center of the screen there will be a pull down menu, select the T8500R in the pull down menu. Models T8500/T8510/T8530 and T8550 are all on the same owners manual, good luck!:)
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
