Refrigerators Logo
Posted on Nov 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A WHIRLPOOL GOLD ITS DIGITAL WHEN I TURN ON THE OVEN IT BEEPS CUT OFF AND SHOW EF-3
Anonymous
Level 3:
  • Master 618 Answers
  • Posted on Nov 17, 2010
Anonymous
Master
Level 3:
Answers
618
Questions
Helped
128762
Points
1840
Need modal off machine itself. Under warmer drawer.
Beeps for no reason but no error code and oven works fine - a Whirlpool gold double oven
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
1helpful
Whirlpool gold accubake system
What is your model number?
I have a whirlpool gold oven that after cleaning the door was locked, after opening door would not bake. Replaced the thermostat (tod) {8300802}that was bad but now the keypad just beeps. Ok, so I replaced...
We are sorry to hear of the problem with your Whirlpool oven. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at [email protected] with your name, phone number, address and the model and serial number for your oven.
Can't turn off the oven
if its push button it should cut off when you push the cancel button
May 01, 2009 • Ovens
2helpful
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
How to turn timer on to cook my turkey while I am out
hi thanks for the question on your timer you have a start time & cooking time or stop time so if you want the oven to come on say at 3 pm then set to 3 pm stop time or cooking time say 5 pm you will then turn on oven at say 350 degrees the oven will then only start at 3 pm and turn off at 5 pm try this once when your at home to see if this works for you thanks the appliance doc
2answers
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
