If not, you'll have to use an ethernet cable to the 2wire router or buy a wireless USB card for about $35 or less for the old Dell. I'm assuming you are running XP SP2 or higher system.
You can manually go into the network settings and delete the old network configuration, and set up a new one. If all else fails, go to your desktop (which I am assuming connects OK) and check the settings on it, and use those to set up the laptop. Hope this helps
If so, go to your router and plug in another ethernet cord into the first,second,third slot and then plug the other end into your desktop's ethernet slot.
you can buy a wireles linksys usb for your lap top and have a wireless router linksys stationary and the lap top usb ..... will pick up the signal for your lap top, i have a usb port linksys and it works great, but u do need a router in your home to pick up the signal
First of all u should ensure that DHCP server is configured for your required number of computers. this problem seems that you have less clients configured in your DHCP server, existing in router configuration.
Is your laptop wireless adapter correctly configured? It may be set to only recieve certain types of signals (802.11b, when you may beed 802.11g etc), so check if the configuration of the laptop matches the configuration of the router.
To test if the laptop can get internet at all, try to get to a wired internet line (your wireless router may have some Ethernet ports on the back; laptops usually have Ethernet connectivity), just incase your laptop is set to block all internet signals coming in.
There is only two ways to possibly connect both the desktop and the laptop in the network. That is to purchase a router so you can connect them both or a route with a wireless and then the laptop (Which most new ones have a wireless capability installed) can connect wireless from anywhere in the home. If you already have a Cable or DSL Modem it may have a wireless capability. Otherwise you would have to get a wireless modem. Hope this helps. Bud
Wireless network adapters require an associated wireless receiver (such as a wireless router or wireless access point) to recieve the radio signals from the adapter and eventually route them to a wire and in you case it would be the wire providing internet services to your desktop computer. If there is no wireless receiver there is no device to convert the radio communications of the wireless adapter and rout those signals to the internet.
YOUR WIRELESS IS
BLUETOOTH OR WIFI?
