Back to:
Tags:
Gateway FPD 1730  17 in. Flat Panel LCD Monitor
Is it a monitor, desktop or other problem?
posted by iknowhuhabby on Jun 18, 2008
Everytime I start-up my computer I see these white lines (circle around with red see image below) and my computer takes about 10 minutes to start-up? Is it a monitor or my computer itself problem? My computer is an Gateway Essential 933c
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 18, 2008
Helpful (85)
edlay
Rank:Master Master
Rating: 88%, 11 votes
it will appear because you did not shut down your computer properly,try to consult to computer technician so they can fixed your computer,its not the monitor its the cpu.
Rating Locked! (?) iknowhuhabby has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Is it a monitor, desktop or other problem?:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
I got a acer monitor with tic-tac sound when power switch...
Monitors
There appears to be a power problem in that when I switch...
Gateway FPD 1730 (Platinum) 17 in. Flat...
on the right side of my computer from top to bottom is...
i could use the inverter but if your trashing the whole...
If you are trashing your monitor before doing so toss me...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
